Results 1 to 12 of 12
  1. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    I started studying drm, for viewing raiplay videos on external players offline; it's been a month now.
    I have been testing WidevineProxy2 v0.8.2 extension (ff and chrome) but not work at windows7 (10+ only). Widevine L3 Guesser Extension and derivate software ok for windows7 because of Manifest v2, but not allow insertion of custom pssh. I don't know python/ js so still can't use py scripts directly.
    Than i wrote this batch script for educational purposes that retrieve quickly the most relevant headers for CDRM-Project or Get Widevine Keys site, and show other data. Also reveal if there is fullhd stream available or not, and subtitles. It works, but maybe someone can optimize the script or give an idea on how to improve it.
    Dependencies are sed.exe (libiconv2.dll, libintl3.dll, regex2.dll too), wget.exe and N_m3u8DL-RE.exe in the "Tvtools" directory on %SystemDrive%.
    N_m3u8DL-RE need ffmpeg.exe, mp4decrypt.exe also.
    ° wget (tested with .exe x64 for windows7 vers: 1.21.4) link
    ° sed (tested with .exe for windows7 vers: 4.2.1) link
    ° N_m3u8DL-RE (tested with .exe x64 for windows7 vers: 0.3.0-beta) link
    ° ffmpeg (tested with .exe x64 vers: 2025-03-03 from ffmpeg-2025-03-03-git-d21ed2298e-essentials_build.7z) link
    ° mp4decrypt (tested with .exe x64 vers: Bento4-SDK-1-6-0-641) link
    Setup: Open notepad or any text editor and copy-paste this script, save as UTF-8 command file (with or without BOM). Create 3 versions with following names: "_Nv.auth.Vers2.2.3-1-challenge.cmd", "_Nv.auth.Vers2.2.3-2-record.cmd" and "_Nv.auth.Vers2.2.3-3-info-only.cmd". That's all. Set main switches within them to change the way these programs work.
    Inside "_*-1-challenge.cmd", set: recording=off, challenge=on, raw=off, textinfo=on.
    Inside "_*-2-record.cmd", set: recording=on challenge=off raw=on textinfo=off.
    Inside "_*-3-info-only.cmd", set: recording=off challenge=off raw=on textinfo=on.
    There are many other optional switches (audio, path etc), you can explore them on your own.
    Features: For those who still use Windows 7, for those who can't get Android emulator working, and need to send custom pssh to server. This script simplifies and speeds up the procedure with drm for standard and hidden pssh. Also usefull for m3u8 VOD, just put the bookmark of web page in the folder and click cmd (script); or drag saved bookmark over the cmd (script) - the download starts immediately. With "_*info-only.cmd" you will be able to view technical and artistic data for video content.
    Usage: If m3u8 (no drm), put in the same folder the bookmark (*.url) of web page raiplay where video content is present and click "_*record.cmd". Or drag saved bookmark over "_*record.cmd". Extremely simple. For viewing data only, use "_*info-only.cmd" instead of "_*record.cmd".
    If mpd (drm), put in the same folder the bookmark (*.url) of web page raiplay where video content is present and click "_*challenge.cmd" or drag saved bookmark over "_*challenge.cmd". this will open your chosen web server "Get Widevine Keys" or "CDRM-Project" and will open the text file showing the headers; it is also opened "_source.txt" where you have to paste key found successfully by the server. Then close all open windows and click "_*record.cmd" or drag saved bookmark over "_*record.cmd".
    Tips: Firefox, some versions, blocks creating bookmarks via drag-and-drop method but you can edit about:config> "browser.launcherProcess.enabled" from "true" to "false" and bypass a limit. Chrome doesn't have this problem.
    To quickly close the text file (and save its contents), web pages, media players... you can install "autohotkey" and write a short script *.ahk that assigns some rarely used keyboard keys to functions as open or close windows or specific software. You can program the Insert key to close all active windows in the foreground, one each time the key is pressed. This helps a lot. For example this will allow notepad to be closed by pressing "insert" (INS) on the keyboard:
    #IfWinActive, ahk_class Notepad
    Ins::WinClose, ahk_class Notepad
    How that work: these scripts are looking for best video resolution, known and hidden, best audio (or all audio tracks depends on switches set within the script) and all subtitles. If there is no drm (.m3u8) than 2° (recording) script show some data in the default text editor, data that can be hidden if not needed, and automatically start downloading; at the end a directory where video is saved and muxed (default: %SystemDrive%\TV) is opened. Otherwise if there is drm (.mpd) the first script (challenge) show valid headers in the default text editor and some data that must be inserted into CDRM-Project or Get Widevine Keys site to get key xxxx : xxxx. This key have to be inserted (copy-paste) into a blank textfile named "_source.txt", prepared and opened by the main (1°) script. After the key has been stored, when click recording (2°) script this takes into account the web address where the video is located which he takes from the bookmark, and the decryption key which he takes from "_source.txt". Mpd is generated from script, you don't need to know it. The bookmark is enough.
    If subtitles is present but not compatible, N_m3u8DL-RE may not detect them or it could detect but fails to save together, and mux them. For this reason subtitles are saved even separately (*.srt format).
    Options: To be able to choose video resolution if no need 1080p, audio quality or language etc apart from the provided switches you can edit the script by yourself (-sv best means best video resolution, -sv res=1600* means 1600x900p stream, -sv res=1440* means 1440x810p stream, -sv res=1280* means 1280x720p stream, -sa lang=Italiano:for=best means italian language, -sa lang=VO:for=best or -sa lang=und:for=best should mean "Versione Originale", original audio version, and -sa all means all available audio tracks muxed.) Sometimes 1600x900p and 1440x810p, are marked as "equal". This is case sensitive:
    "-sa lang=it:for=best" or "-sa lang=italiano:for=best", it might not work.
    "-sa lang=it*:for=best" or "-sa lang=Italiano:for=best", it might work.
    Use this tool only for educational purposes and for watching VOD offline if you have rights to watch content, and download only if you have rights to download it.
    If it doesn't work on some pages it's probably a technical error on the page itself, or this is obsolete, you can write url in pm so I can check. If you have trouble with some UNICODE/ UTF characters in the titles, description of shows, actors, directory names explain the problem and mention the country or default language of your computer/ device so i can reproduce the situation and try to resolve it.
    *Note 1: when i say drag bookmark over one of three cmd's, this means that you must drag and drop over the "cmd" (closed) symbol in the folder, not over an already open cmd. You don't need to open it (click). If not, the other method is to open it (click) without dragging - either one or the other, not both. ^___^
    *Note 2: This is for raiplay only, need italian ip/ proxy and free account.
    Once you have m3u8 or mpd and key, download is possible also without italian ip. In that case, use the usual syntax N_m3u8DL-RE -M mp4 --key xxxx mpd -sv best -sa all -ss all --save-name title --check-segments-count false.
    Bookmarks must be originally formatted without modifications, not renamed! The simplest way to generate bookmark in the desired folder is: drag padlock symbol on your browser near "https" to folder where script is. Only one bookmark is processed, so remove others, or move them into "a-d-d-r-e-s-s" folder. If you are watching tv series example *S1-E1*, *S1-E2* the script will process last bookmark alphabetically, no need remove old below a number 10.
    If you set the switch "raw"=on, raw data (json, xml, m3u8, mpd) will be created in the i-n-f-o directory for statistical/ analytic purposes.
    @echo off&& cd /D "%~dp0"&& chcp 1252&& cls
      title=  - - s e a r c h n v a u t h - - G.T.X.R. Vers: 2.2.3
    rem SWITCH: {toggle} recording on or off
    set "recording=on"
    rem SWITCH: {toggle} search keys online on or off
    set "challenge=off"
    rem SWITCH: {toggle} create RAW info data on or off
    set "raw=on"
    rem SWITCH: {toggle} show textinfo on or off
    set "textinfo=on"
    rem SWITCH: {toggle} pause before exit on or off
    set "pause=on"
    rem SWITCH: {toggle} server 'Get Widevine Keys' or 'CDRM-Project'
    set "server=Get Widevine Keys"
    rem SWITCH: {toggle} debug mode on or off
    set "debug=off"
    :: :: Choose Your default audio |Language|: ::::: ::
    :: ::::::: (Italiano¦VO¦und¦Audiodescrizione):::: ::
        set "Language=Italiano"
    rem set "Language=VO"
    rem set "Language=Audiodescrizione"
    rem set "Language=und"
    :: :: Choose |Audio| tracks, if Multiaudio: ::::: ::
    rem set "Track=BEST"
    rem set "Track=1"
        set "Track=ALL"
    :: :::::::::::: Choose Video save directory: :::: ::
    set "direct=%systemDrive%\TV"
    if not exist "%direct%" mkdir "%direct%"
    :: :::::: Choose |Software directory|: :::::::::: ::
    set "sw.TV=%systemdrive%\Tvtools"
    if not exist "%sw.TV%" mkdir "%sw.TV%"
    SETLOCAL ENABLEEXTENSIONS DISABLEDELAYEDEXPANSION
    echo.:: ========================================================== ::
    echo.  - - s e a r c h  n v  a u t h - Vers: 2.2.3 .m3u8 + .mpd - -
    if not exist ".\a-d-d-r-e-s-s" mkdir ".\a-d-d-r-e-s-s"
    if exist "*- RaiPlay.url" ( for /f "tokens=1,2,3 delims=:" %%i IN ('findstr /B /I "URL" "*- RaiPlay.url"') do ( set url=%%j:%%k ) )
    if not "%url%"=="" ( set url=%url:~4% )
    if not exist "_source.txt" echo.> "_source.txt"
    %sw.TV%\sed "/^$/d" "_source.txt" > "source-0.txt"
    move "source-0.txt" "_source.txt">nul
    if exist "_source.txt" ( (FOR /L %%W IN (1,1,1) DO SET /P "line-1=") < "_source.txt" )
    set "key=%line-1%"
    if not "%url%"=="" (goto data)
    echo.+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
    echo.\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.\\\\\\\\\\\\\\\\\\ if missing data: \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.\\\\\\\ insert decryption KEY from 'Get Widevine Keys' or \\\\\\\\\
    echo.\\\\\\\ 'CDRM-Project' site to line 1 of "_source.txt".    \\\\\\\\\
    echo.\\\\\\\                                                   \\\\\\\\\
    echo.\\\\\\\  put in this folder bookmark of page "raiplay.it" \\\\\\\\\
    echo.\\\\\\\ (*.url) where VIDEO content is present.           \\\\\\\\\
    pause
    exit
    :data
    if "%server%"=="Get Widevine Keys" ( set "servst=http://108.181.133.95:8080/" )
    if "%server%"=="CDRM-Project" ( set "servst=https://cdrm-project.com/" )
    if "%challenge%"== "on" (
    if "%recording%"=="off" ( if exist "_source.txt" start "" "_source.txt" )
    if "%recording%"=="off" ( start "" "%servst%" )
    set "REF=https://www.raiplay.it"
    set "Agent=Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:109.0) Gecko/20100101 Firefox/115.0"
    rem ::IT= 151.81.0.0 151.100.255.255::
    rem :: : ::::r a n d o m  i p:::: : ::
    set maxval1=151
    set minval1=151
    set maxval2=100
    set minval2=81
    set maxval3=255
    set minval3=0
    set maxval4=255
    set minval4=0
     SET /A N0=%RANDOM% * 255 / 32768
     SET /A N1=%RANDOM% * ^(%maxval1% - %minval1% + 1^) / 32768 + %minval1%
     SET /A N2=%RANDOM% * ^(%maxval2% - %minval2% + 1^) / 32768 + %minval2%
     SET /A N3=%RANDOM% * ^(%maxval3% - %minval3% + 1^) / 32768 + %minval3%
     SET /A N4=%RANDOM% * ^(%maxval4% - %minval4% + 1^) / 32768 + %minval4%
    SET  "IP=%N1%.%N2%.%N3%.%N4%"
    if "%Track%"=="BEST" ( set "Audio=best" )
    if "%Track%"=="1" ( set "Audio=lang=%Language%:for=best" )
    if "%Track%"=="ALL" ( set "Audio=all" )
    if exist ".\*.log" del /F /Q ".\*.log"
    echo.%url%| %sw.TV%\sed "s/\(https:\/\/www.raiplay.it\/video\/.*\)\.html/\1.json/gi; " > "b.log"
    for /f "usebackq tokens=* delims=*" %%F in ("b.log") do ( %sw.TV%\wget -c --no-check-certificate -U "%Agent%" --referer=%REF% --header="X-Forwarded-For:%IP%" %%F -q -O "c.log" )
    %sw.TV%\sed "s/\x22, \x22/\x22, \n \x22/gi; " "c.log" > "d.log"
    %sw.TV%\sed "s/,/,\n/g;" "d.log" >> "p-x.log"
    %sw.TV%\sed "/[a-zA-Z]\.srt/!d; s/\"url\":\"\(\/dl\/video\/stl\/[a-z_0-9A-ZÈàèéìòùËëÇçÑñ].*\.srt\)\".*/https:\/\/www.raiplay.it\1/gi; " "p-x.log" | %sw.TV%\sed -nr "G;/^([^\n]+\n)([^\n]+\n)*\1/!{P;h}; " > "p.log"
    %sw.TV%\sed "/eeqqEEqual/!d; " "d.log" > "e.log"
    %sw.TV%\sed "s/\s.video.:\s{\s\s.content_url.:\s.\(https:\/\/mediapolisvod\.rai\.it\/relinker\/relinkerServlet\.htm?cont=.*eeqqEEqual\).*$/\1/gi; " "e.log" > "f.log"
    for /f "usebackq tokens=* delims=*" %%X in ("f.log") do ( set "XML=%%X^&forceUserAgent=mpd-5000^&output=64" )
    if "%XML%"=="" (goto next)
    %sw.TV%\wget -c --no-check-certificate -U "%Agent%" --header="X-Forwarded-For:%IP%" %XML% -q -O "g.log"
    %sw.TV%\sed "/Authorization=/!d; " "g.log" > "h.log"
    %sw.TV%\sed "s/.*Authorization=\(ey.*\)\",\"name.*/{\"Nv-Authorizations\": \"\1\"}\n\nurl license:\n-------------\nhttps:\/\/rai6nb5f.anycast.nagra.com\/RAI6NB5F\/wvls\/contentlicenseservice\/v1\/licenses/gi; " "h.log" > "i.log"
    %sw.TV%\sed "/<!\[CDATA\[https/!d; /vtt_poster/d; " "g.log" > "j.log"
    %sw.TV%\sed "s/.*<!\[CDATA\[\(https.*\)\]\]>/\1/gi; " "j.log" > "k.log"
    for /f "usebackq tokens=* delims=*" %%M in ("k.log") do ( set "mpd=%%M" )
    if "%mpd%"=="https://download-rai-it.akamaized.net/video_no_available.mp4" (
    echo.>> "i.log"
    echo.//// Video unknown type //// - - -:>> "i.log"
    echo.------------------------------------------>> "i.log"
    echo.This script need italian ip or proxy but download from known m3u8 and mpd not.>> "i.log"
    goto ip
    set "mpd_=%mpd:&=^^^&%"
    %sw.TV%\wget -c --no-check-certificate -U "%Agent%" --header="X-Forwarded-For:%IP%" "%mpd%" -q -O "l.log"
    echo.0000> "q.log"
        find /c "1200" "k.log" >NUL
        if %errorlevel% equ 0 echo.522p,432p> "q.log"
        find /c "1800" "k.log" >NUL
        if %errorlevel% equ 0 echo.576p> "q.log"
        find /c "2400" "k.log" >NUL || find /c ",2401" "k.log" >NUL
        if %errorlevel% equ 0 echo.720p> "q.log"
        find /c "3600" "k.log" >NUL
        if %errorlevel% equ 0 echo.900p,810p> "q.log"
        find /c "5000" "k.log" >NUL
        if %errorlevel% equ 0 echo.1080p> "q.log"
    for /f "usebackq tokens=* delims=*" %%R in ("q.log") do ( set "res=%%R" )
    if "%res%"=="0000" (
        find /c "RESOLUTION" "l.log" >NUL
        if %errorlevel% equ 0 echo.[random res]> "q.log"
    %sw.TV%\sed "/<cenc:pssh>/!d; " "l.log" > "m.log"
    %sw.TV%\sed "s/.*<cenc:pssh>\(AAAA.*\)<\/cenc:pssh>.*/\1/; " "m.log" > "n.log"
    %sw.TV%\sed -e "2,$d" "n.log" > "o.log"
    :next
    for /f "usebackq tokens=* delims=*" %%A in ("o.log") do ( set "AAAA=%%A" )
    echo.%AAAA% | findstr /C:"AAA">nul && ( echo.>nul ) || ( echo.Nv-Authorizations: no need, license: no need {= n  o   d  r  m =}> "o.log" )
    for /f "usebackq tokens=* delims=*" %%E in ("e.log") do ( set "EXP=%%E" )
    echo.%EXP% | findstr /I /C:"url">nul && ( echo.>nul ) || ( echo. j s o n   m i s s i n g> "o.log" )
    for /f "usebackq tokens=* delims=*" %%P in ("o.log") do ( set "pssh=%%P" )
    echo.>> "i.log"
    echo.pssh %res%:>> "i.log"
    echo.-------------->> "i.log"
    echo.%pssh%>> "i.log"
    echo.%mpd_%| findstr /I /C:".m3u8">nul && ( set "type=m3u8" ) || ( set "type=mpd" )
    echo.%EXP%| findstr /I /C:"url">nul && ( echo.>nul ) || ( set "type=m3u8 / mpd" && set "space= " )
    echo.>> "i.log"
    echo.%type% %res%:>> "i.log"
    echo.%mpd_%>> "i.log"
    :ip
    for /f "usebackq tokens=* delims=*" %%U in ("p.log") do ( set "subt=%%U" )
    if "%subt%"=="" ( echo. n o  s u b t i t l e s> "p.log" ) ELSE ( echo.>nul )
    echo.>> "i.log"
    echo.subtitles%space%:>> "i.log"
    for /f "usebackq tokens=* delims=*" %%C in ("p.log") do ( echo.%%C>> "i.log" )
    if "%XML%"=="" (goto end)
    %sw.TV%\sed "/.*{.*}.*/d; s/\&/+/g; /^.\"name\":.\".*\",.$/!d; " "d.log" > "q2.log"
    %sw.TV%\sed -e "2,$d" "q2.log" > "q3.log"
    %sw.TV%\sed "s/\\\x22/~/g; s/^.\"name\":.\"\(.*\)\",.$/\1/gi; " "q3.log" > "q4.log"
    for /f "usebackq tokens=* delims=*" %%T in ("q4.log") do ( set "title-1=%%T" )
    %sw.TV%\sed "s/\&/+/g; /^.\"toptitle\":.\".*\",.$/!d; " "d.log" > "r2.log"
    %sw.TV%\sed -e "2,$d" "r2.log" > "r3.log"
    %sw.TV%\sed "s/\\\x22/~/g; s/^.\"toptitle\":.\"\(.*\)\",.$/\1/gi; " "r3.log" > "r4.log"
    for /f "usebackq tokens=* delims=*" %%Q in ("r4.log") do ( set "title-3=%%Q" )
    %sw.TV%\sed "/.*{.*}.*/d; s/\&/+/g; /^.\"subtitle\":.\".*\",.$/!d; " "d.log" > "s2.log"
    %sw.TV%\sed -e "2,$d" "s2.log" > "s3.log"
    %sw.TV%\sed "s/\\\x22/~/g; s/^.\"subtitle\":.\"\(.*\)\",.$/\1/gi; " "s3.log" > "s4.log"
    for /f "usebackq tokens=* delims=*" %%D in ("s4.log") do ( set "title-4=%%D" )
    %sw.TV%\sed "s/\&/+/g; /^.\"description\" :.\".*\",.$/!d; " "d.log" >> "t2.log"
    %sw.TV%\sed "s/\\\x22/~/g; s/^.\"description\" :.\"\(.*\)\",.$/\1/gi; " "t2.log" > "t4.log"
    for /f "usebackq tokens=* delims=*" %%L in ("t4.log") do ( set "desc-L=%%L" )
    %sw.TV%\sed "s/\&/+/g; /^.\"description\":.\".*\",.$/!d; " "d.log" >> "t3.log"
    %sw.TV%\sed "s/\\\x22/~/g; s/^.\"description\":.\"\(.*\)\",.$/\n\1/gi; " "t3.log" >> "t5.log"
    for /f "usebackq tokens=* delims=*" %%G in ("t5.log") do ( set "desc-G=%%G" )
    set "description=%desc-L% (%desc-G%)"
    echo.%description%> "y1.log"
    %sw.TV%\sed "s/\\/~/g; s/²/\xB2/g; s/³/\xB3/g; s/º/\xBA/g; s/ª/\xAA/g; s/°/\xB0/g; s/©/\xA9/g; s/È/\xC8/g; s/à/\xE0/g; s/á/\xE1/g; s/â/\xE2/g; s/ã/\xE3/g; s/ä/\xE4/g; s/å/\xE5/g; s/æ/\xE6/g; s/ç/\xE7/g; s/è/\xE8/g; s/é/\xE9/g; s/ê/\xEA/g; s/ë/\xEB/g; s/ì/\xEC/g; s/í/\xED/g; s/î/\xEE/g; s/ï/\xEF/g; s/ð/\xF0/g; s/ñ/\xF1/g; s/ò/\xF2/g; s/ó/\xF3/g; s/ô/\xF4/g; s/õ/\xF5/g; s/ö/\xF6/g; s/÷/\xF7/g; s/ø/\xF8/g; s/ù/\xF9/g; s/ú/\xFA/g; s/û/\xFB/g; s/ü/\xFC/g; s/ý/\xFD/g; s/þ/\xFE/g; s/ÿ/\xFF/g; s/  / /g; " "y1.log" > "y2.log"
    for /f "usebackq tokens=* delims=*" %%Y in ("y2.log") do ( set "desc=%%Y" )
    %sw.TV%\sed "s/\&/+/g; /^.\"actors\":.\".*,.*\",.$/!d; " "d.log" > "u2.log"
    %sw.TV%\sed -e "2,$d" "u2.log" > "u3.log"
    %sw.TV%\sed "s/\\\x22/~/g; s/^.\"actors\":.\"\(.*\)\",.$/\1/gi; " "u3.log" > "u4.log"
    for /f "usebackq tokens=* delims=*" %%O in ("u4.log") do ( set "title-7=%%O" )
    set "actors=%title-7%"
    echo.%actors%> "z1.log"
    %sw.TV%\sed "s/:/./g; s/|/\xA6/g; s/</\xAB/g; s/>/\xBB/g; s/\\/~/g; s/\//~/g; s/?/^/g; s/\x22/''/g; s/\x2a/\xB0/g; s/²/\xB2/g; s/³/\xB3/g; s/º/\xBA/g; s/ª/\xAA/g; s/°/\xB0/g; s/©/\xA9/g; s/È/\xC8/g; s/à/\xE0/g; s/á/\xE1/g; s/â/\xE2/g; s/ã/\xE3/g; s/ä/\xE4/g; s/å/\xE5/g; s/æ/\xE6/g; s/ç/\xE7/g; s/è/\xE8/g; s/é/\xE9/g; s/ê/\xEA/g; s/ë/\xEB/g; s/ì/\xEC/g; s/í/\xED/g; s/î/\xEE/g; s/ï/\xEF/g; s/ð/\xF0/g; s/ñ/\xF1/g; s/ò/\xF2/g; s/ó/\xF3/g; s/ô/\xF4/g; s/õ/\xF5/g; s/ö/\xF6/g; s/÷/\xF7/g; s/ø/\xF8/g; s/ù/\xF9/g; s/ú/\xFA/g; s/û/\xFB/g; s/ü/\xFC/g; s/ý/\xFD/g; s/þ/\xFE/g; s/ÿ/\xFF/g; s/  / /g; " "z1.log" > "z2.log"
    for /f "usebackq tokens=* delims=*" %%Z in ("z2.log") do ( set "act=%%Z" )
    if "%act%"=="" ( set "act=?" )
    echo.>> "i.log"
    echo.description:>> "i.log"
    echo.%desc%>> "i.log"
    echo.>> "i.log"
    echo.actors:>> "i.log"
    echo.%act%>> "i.log"
    set "title-temp=%title-1% {©RAI-play-it}"
    echo.%title-temp%> "v.log"
    %sw.TV%\sed "s/:/./g; s/|/\xA6/g; s/</\xAB/g; s/>/\xBB/g; s/\\/~/g; s/\//~/g; s/?/^/g; s/\x22/''/g; s/\x2a/\xB0/g; s/²/\xB2/g; s/³/\xB3/g; s/º/\xBA/g; s/ª/\xAA/g; s/°/\xB0/g; s/©/\xA9/g; s/È/\xC8/g; s/à/\xE0/g; s/á/\xE1/g; s/â/\xE2/g; s/ã/\xE3/g; s/ä/\xE4/g; s/å/\xE5/g; s/æ/\xE6/g; s/ç/\xE7/g; s/è/\xE8/g; s/é/\xE9/g; s/ê/\xEA/g; s/ë/\xEB/g; s/ì/\xEC/g; s/í/\xED/g; s/î/\xEE/g; s/ï/\xEF/g; s/ð/\xF0/g; s/ñ/\xF1/g; s/ò/\xF2/g; s/ó/\xF3/g; s/ô/\xF4/g; s/õ/\xF5/g; s/ö/\xF6/g; s/÷/\xF7/g; s/ø/\xF8/g; s/ù/\xF9/g; s/ú/\xFA/g; s/û/\xFB/g; s/ü/\xFC/g; s/ý/\xFD/g; s/þ/\xFE/g; s/ÿ/\xFF/g; s/  / /g; " "v.log" > "w.log"
    for /f "usebackq tokens=* delims=*" %%V in ("w.log") do ( set "save=%%V" )
    echo.>> "i.log"
    echo.title video: {©R A I-P L A Y-I T}>> "i.log"
    echo.^> ^> ^> ^>%save%^< ^< ^< ^<>> "i.log"
    echo.>> "i.log"
    echo.save as:>> "i.log"
    echo.%direct%\%save%.mp4>> "i.log"
    echo.>> "i.log"
    echo. @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@>> "i.log"
    echo.   - - s e a r c h n v a u t h - - .m3u8 + .mpd =^> %date% %time%>> "i.log"
    echo.Script G.T.X.R. Version 2.2.3>> "i.log"
    :end
    set "info=.\i-n-f-o ''%save%''"
    if exist "%info%" del /F /Q "%info%\*"
    if not exist "%info%" mkdir "%info%"
    if exist "%info%\new.data.*p.txt" del /F /Q "%info%\new.data.*p.txt"
    if exist "%info%\new.data.expired.txt" del /F /Q "%info%\new.data.expired.txt"
    if "%res%"=="" ( set "res=expired" )
    %sw.TV%\sed "s/©/\xA9/g; s/\^//g; " "i.log" >> "x.log"
    if exist "x.log" copy /Y "x.log" "%info%\new.data.%res%.txt">nul
    if "%textinfo%"=="on" ( if exist "%info%\new.data.%res%.txt" start "" "%info%\new.data.%res%.txt" )
    for /f "usebackq tokens=* delims=*" %%B in ("p.log") do ( set "subt=%%B" )
    %sw.TV%\wget -c --no-check-certificate -U "%Agent%" --referer=%REF% --header="X-Forwarded-For:%IP%" "%subt%" -q --directory-prefix="%info%"
    if "%res%"=="0000" ( if not "%debug%"=="on" ( if exist ".\*.log" del /F /Q ".\*.log" ) && goto error )
    if "%XML%"=="" (goto skip.info)
    rem :: ================== ::
      if not "%raw%"=="on" (goto skip.info)
    echo.[InternetShortcut]> "%info%\%save%.url"
    echo.URL=%url%>> "%info%\%save%.url"
    echo.IDList=>> "%info%\%save%.url"
    echo.HotKey=^0>> "%info%\%save%.url"
    echo.IconFile=>> "%info%\%save%.url"
    echo.IconIndex=^0>> "%info%\%save%.url"
    echo.>> "%info%\%save%.url"
    for /f "usebackq tokens=* delims=*" %%N in ("b.log") do ( %sw.TV%\wget -c --no-check-certificate -U "%Agent%" --referer=%REF% --header="X-Forwarded-For:%IP%" %%N -q -P "%info%" )
    copy /Y ".\d.log" "%info%\s e p a r a t e (CRLF).txt">nul
    %sw.TV%\sed "s/\s.video.:\s{\s\s.content_url.:\s.https:\/\/mediapolisvod\.rai\.it\/relinker\/relinkerServlet\.htm?cont=\(.*\)eeqqEEqual.*$/\1/gi; s/eeqqEEqual//; " "e.log" > "a.log"
    for /f "usebackq tokens=* delims=*" %%H in ("a.log") do ( set "high=%%H" )
    %sw.TV%\wget -c --no-check-certificate -U "%Agent%" --header="X-Forwarded-For:%IP%" %XML% -q -O "%info%\%high%.xml"
    if "%type%"=="mpd" ( copy /Y ".\l.log" "%info%\Media Presentation Description.mpd">nul )
    if "%type%"=="m3u8" ( copy /Y ".\l.log" "%info%\Multimedia MP3 URL (Version 8).m3u8">nul )
    for /f "usebackq tokens=* delims=*" %%S in ("p.log") do ( %sw.TV%\wget -c --no-check-certificate -U "%Agent%" --referer=%REF% --header="X-Forwarded-For:%IP%" %%S -q -P "%info%" )
               :skip.info
    set "m3u8.or.mpd=%mpd%"
    set "m3u8.or.mpd_=%mpd_%"
    set "title=%save%"
    echo.\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.\\\\\\\\\\\\\\\\\\\\\\\\\\\KEYS\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.......................................................................
    echo.  %key%
    echo.
    echo.\\\\\\\\\\\\\\\\\\\\\ description\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.  %description%
    echo.
    echo.\\\\\\\\\\\\\\\\\\\\\\\\\\actors \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.  %actors%
    echo.
    echo.\\\\\\\\\\\\\\\\\\\\\\\\\\\ URL\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.  %url%
    echo.
    echo.\\\\\\\\\\\\\\\\\\\\\\\\\\\\TITLE\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.    %title%
    echo.
    echo.\\\\\\\\\\\\\\\\\\\\\\\\\\M3U8 or MPD\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.  %m3u8.or.mpd_%
    echo.
    set "m3u8.or.mpd=%m3u8.or.mpd: =%"
    set "key=%key: =%"
    echo.\\\\\\\N_m3u8DL-RE\\\\\\\\ parameters\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    echo.    -M mp4 --key "%%key%%" "%%m3u8.or.mpd%%" -sv best -sa %Audio% -ss all --check-segments-count false --tmp-dir "%direct%" --save-dir "%direct%" --save-name "%%title%%" -H "User-Agent: %Agent%" -H "Referer: %REF%" -H "X-Forwarded-For: %IP%"
    echo.\\\\\\\\\\\\\\\\\\\\\\\\\\ parameters\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    if "%save%"=="" ( goto error )
    echo.
    echo.   ^> ^> ^> ^>  d o w n l o a d i n g        m e t a d a t a    a n d    p a u s e/ exit
    if "%recording%"=="on" (goto rec)
    rem pause
    exit
    :rec
    echo.
    echo.  - r e c o r d i n g s t r e a m - Vers: 2.2.3 .m3u8 + .mpd -
    echo.
    %sw.TV%\N_m3u8DL-RE -M mp4 --key "%key%" "%m3u8.or.mpd%" -sv best -sa %Audio% -ss all  --check-segments-count false --tmp-dir "%direct%" --save-dir "%direct%" --save-name "%title%" -H "User-Agent: %Agent%" -H "Referer: %REF%" -H "X-Forwarded-For: %IP%"
    echo. END - r e c o r d i n g s t r e a m - .m3u8 + .mpd = %date% %time%
    if exist "%direct%" start "" "%direct%"
    if "%pause%"=="on" ( pause )
    :error
  2. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    Updated information in 1st post, since this guide is intended for beginners, and some concepts were not clear.
    Updated script from 2.2.2 to vers. 2.2.3 fixed two bugs: "&" in video titles as well as errors on webpage would break the program, now shows "random res" wording if resolution is wrong without stop to work. Accented characters in languages ​​other than Italian have also been corrected.
    The three *.cmd (command file for windows) are also available as zip, here. Any comments, suggestions or questions are welcome!
  3. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    Version 2.2.4 can be found here.
    Changelog
    °Temporary files have been moved to the %temp% directory, but still remain in the current directory if the script is in debug mode.
    °Bookmarks in the current directory are now automatically moved to "a-d-d-r-e-s-s" after the download is complete.
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Thanks for sharing
    Always nice to see people sharing their works
  5. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    Experimental version 2.2.5, here.
    Now the script fills in the form of the chosen server (pssh, license url, headers) and shows the key. Tested on Get Widevine Keys not tested on CDRM-Project because it is down.
    If an error appears, such as insufficient disk space, it automatically cancels the partial download, and only in case of success it opens the directory and moves the bookmark to "a-d-d-r-e-s-s".
    If the name is already present, it deletes the file because it is assumed that it is a residue of a previous failed download.
    Note: setting raw=on, the start is slow; setting raw=off, the start is very fast.
    Note 2: Please wait 5 seconds to see the form fill itself...
    EDIT. Sorry, i uploaded wrong file, delete that and refresh the page to get the right one!
  6. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    //// Version 2.2.6 is here! ////
    Fixed bug "special character ’ (U+2019) if contained in video title blocks script".
    Fixed bug "if raw is set to off not all subtitles are saved".
    Now the key is found automatically, no more copying and pasting of data (the form fills itself in, shows the result and stores it in the text file _source.txt, ready to be used by '*record*.cmd').
    Detects the content type, if it is a TV series it adds S1-E1... to the file name.
    Verified that it works with both servers (Get Widevine Keys and CDRM-Project).
    ° How to use version 2.2.6 ?
    - Drag the bookmark of the raiplay page with the video, into the folder where the three scripts (*.cmd) are located directly from the browser.
    - if there is no drm, then click on *record*.cmd
    - if there is drm click first on *challenge*.cmd and wait about 15 seconds. Once you have obtained the key and it is automatically saved (all windows will close by themselves), click on *record*.cmd
    - '*info-only*.cmd' is optional, it is only used to get more information about the viewed content.
    To do:
    - turn the script into a mass downloader, maybe
    - figure out why this link is not hooked
    - merge the two main scripts, so that it decides what to do on its own
    P.S.: Bookmark must contain link to the page with video, not to the page with description only. If it does not contain link to the page with video, press f5, then recreate bookmark.
  7. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    Version 2.2.7 of Searchnvauth
    >>>Download<<<
    1. Rewritten, then optimized the code - faster script
    2. adapted to the new version of CDRM-Project
    3. added support for chrome edge opera /as well as firefox
    4. fixed CMD window title
    5. added choice to use 'path' or 'custom' directory for executables**
    6. added choice to save *.srt subtitles
    7. show content type*
    8. better title handling according to type
    9. better partial download handling
    10. move i-n-f-o folder to a-d-d-r-e-s-s after download
    11. fixed special characters including "–" (U+2013) and brackets
    12. show 'exact' resolution according to more accurate server data
    13. if available, show video length
    14. removed double spaces or repetitions in titles
    15. moved the _source.txt file containing the key, in the temporary directory
    16. also stores the key in the i-n-f-o folder, as soon as recording starts
    17. added choice to save the background image
    18. added choice to show background image in the default browser.
    **N_m3u8DL-RE.exe, wget.exe, sed.exe, ffmpeg.exe, mp4decrypt.exe
    *Film, Serie TV, Fiction, Kids, Documentari, Programmi Tv, Musica
    Note 1: Already set to "path" so it can be used immediately.
    Note 2: As previously said, it is not necessary to manually copy the key.
    Note 3: Set the default browser between firefox-chrome-edge-opera !
  8. Hi, in the meantime thank you for your work, but I will be clueless but I can't get it to work, but wasn't it better to give it as input the video page link instead of bookmark? Could you give an example of using it with pictures or an explanatory video? You won't believe it but I get it much easier with widevineproxy2 and ytdlp-interface.
  9. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    Version _Nv.auth.Vers2.2.8..zip is ready for download!
    Hi, I like the bookmark method because it is very fast. However, version 228 has some changes in this regard...
    You are right, in most cases this script is not needed. But in some cases, for me for example it is very useful. The new version has the functions you requested and I will try to realize a tutorial with images or videos. The site has changed, for a few days when you try to create individual bookmark files from the browser to the current folder, often the bookmark generated is no longer correct (wrong name - while url inside it sometimes works and sometimes not). The workaround would be to press f5 before generating bookmarks. I find it inconvenient so I adapted the script, which is becoming increasingly complex, to these changes. Now the script accepts all old and new bookmarks, even those that do not contain the url of the video page but only the description page. The bookmark is now automatically renamed and corrected.
    News:
    - added a possibility to insert manually the url of web page with video, inside the script, or through "set /p". This must be done for each of 3 cmd scripts, or that script you want to use. If bookmark file is used instead, leave that variable empty.
    The new data entry mechanism:
    If url is written manually inside the script, that url is valid for the related script if nothing is entered at the command prompt but enter is pressed.
    If, instead, url is entered at the command prompt (copy paste) and enter is pressed, it overwrites the one possibly written inside the script.
    If both are missing, then the url obtained from the single bookmark file, present in the same folder where the 3 scripts are located, is a valid url.
    If all three are missing (the variable inside the script is empty + nothing is entered at the command prompt but enter is pressed + there are no single bookmark files in the folder) a "missing data" warning is displayed.
    In the options, the method 'Command prompt' can be skipped if it is not used (set "enter=skip").
    Probable errors when using script, and workarounds:
    - an Italian IP is required and it seems that the server does not accept VPN and proxy, generally.
    - *challenge.cmd is set to delay 5 seconds before open the default browser. 3 seconds is sufficient on fast PC and when browser is already running in background, minimized. If PC is slow, or default browser open slowly, or you are behind a VPN, than you may change 5 seconds to 7-8 seconds or more, otherwise the script can't proceed. If your pc and browser is fast change "5" to "4" or "3" in settings inside a script.
    - *challenge.cmd requires you set, inside that script, default browser between firefox chrome edge and opera because browsers behaves differently with form and tab functions. If default browser is not set, this script can't fill form with correct data and send request to server Get Widevine Keys or CDRM-Project.
    - when click to *challenge.cmd, mouse and keyboard must not be used for about 15 seconds. The script automatically collect data from raiplay bookmark (or manually inserted url), open default browser, fill form of choosen server, send request, save results to default location usually %userprofile% \ downloads, copy source of saved page to temp folder, extract the decryption key and save it to "_source.txt" recently moved to %temp%\nv. All this threads has been automated so no user interaction is needed. At the end of this process of 15 seconds - during which no interaction is permitted, browser window closes on its own. Next, when you click on *record.cmd, this other script retrieves the key from "_source.txt" and passes it to N_m3u8DL-RE for download; it is also stored in 'LastDecryptionKey.txt' in the info folder.
    - wget.exe, sed.exe, ffmpeg.exe, mp4decrypt.exe, N_m3u8DL-RE.exe with related *.dll must be in the PATH, I put them in %systemdrive%\Tvtools however you can choose another location, set that location in the options of the 3 scripts.
    How do I use it?
    If there is no DRM:
    Usually after creating the bookmark in the same folder by dragging it (padlock symbol) from the browser, I first click on *info-only.cmd to quickly view the technical and artistic information of the content, which opens in notepad, then after closing notepad I click on *record.cmd.
    Or, if there is DRM:
    Usually after creating the bookmark in the same folder by dragging it (padlock symbol) from the browser, I first click on *info-only.cmd to quickly view the technical and artistic information on the content, which opens in notepad, then after closing notepad I click on *challenge.cmd and wait about 15 seconds for the procedure to finish. At the end I click on *record.cmd.
    After the download, if it was successful, the destination folder opens automatically, for example %systemdrive%\TV (see options inside scripts).
    No need to click *info-only.cmd, it's optional.
    Who needs this script?
    I wrote this script because couldn't find the keys for 1080p with browser extensions and yt-dlp, also I often use Windows 7, incompatible with Manifest v3 and WidevineProxy2. It's inconvenient for me to search each time for headers in dev-tools (I don't know python and js well enough to modify the existing py or js scripts). Obviously for not DRM content it's sufficient yt-dlp and for 720p DRM it's sufficient Guesser. But this script add correct title on downloaded file and offer many additional info, useful for some people. Finally, I find that doing this type of batch is both fun and educational, for myself and others. I am also a supporter of automation in every field or human activity...
  10. Excuse me but yt-dlp has been quietly finding 1080p on raiplay for years, whether you then have trouble finding the drm of 1080p is another matter, but the unprotected ones you can quietly download at 1080p, then if you use any interface it is even easier, like ytdlp-interface, your program would be convenient only for drm protected videos and it would be more convenient if you could use a local CDM
  11. hello and thanks, Am I wrong or is source.tv not getting the key correctly?
